My car (2002 ep3 ctr) died on idle the other day and after starting again I got a MIL. I drove home carefully (a couple of minutes only), then checked and cleared the codes. There was a P1361 which I gather is a TDC sensor intermittent signal issue. After this I tried to start the car but the battery was dead. I then charged the battery and started again. No MIL and car was running fine. After a few minutes on idle (waiting for windows to de-fog) the engine cut out again and MIL came on. I took her for a spin anyway and everything seems normal apart from the light. Battery voltage was well above 13V with the engine running so I don't think there is a problem related to charging or the battery.
Now I'm thinking that possibly there is something in the TDC wiring shorted to the ground or possibly the sensor itself is shorted. Is that even possible? I wont have a chance to remove the sensor until hopefully next week.
Has anyone had problems with the TDC sensor or knows how it works/ should work? How can I test it? I found instructions for testing the TDC on a non-type r civic but I have no idea if the wiring is the same.
Also if there is some instruction to replace it, I would very much appreciate it since I have not been able to find one for the K20A2. Is it a must to remove the valve cover in order to get to the TDC sensor?
