ian
Red Snapper
I had my Tein springs fitted yesterday, with new camber bolts and rear arms, and had a full alignment done. Overall I'm chuffed to bits with the results. It looks the nuts, (only 25 and 20mm lower tho,) and handles really well. 8)
However, the front near side damper is making a loud clunk noise over some bumps and its really bugging me. I took the car back and they double checked everything was tight, which is was. :?
The mechanic suggested it could be the spring coils hitting each other as they compress, although it doesn't sound that metallic and is only happening on the one corner. :? :?
He also suggested that maybe the damper on that corner of the car is a little worn, (the car's only done 40k miles tho,) and that might be the problem :?:
My choices are: change back to standard springs and loose the cash I spent fitting these. Not a great option.
Fit Eibach (sp) springs instead which have better plastic covers over the top coils, and have it all re-set up. This will be costly tho, and still might not solve it. :cry:
Replace the potentially worn damper, (both sides I expect) and see if the noise goes. Again, could be costly, but I have no idea how much the dampers are.
Has anyone suffered similar problems, or can anyone please offer any advice on what to do?
I haven't named the garage because the service was second to none and I do trust that they have fitted everything perfectly and don't want to tarnish their good reputation. 8)
Any help much appreciated, thanks guys. :wink:
Ian
Ian
