Sorry about the length of post, if it's tl;dr:
Can you try to use your window auto-up (driver's side) whilst accelerating and report back if your window will completely close or if it stops midway as you're accelerating?
----- Main Post -----
Hi,
I'm still having some weird gremlin with my electric window (driver's side). It's an EP3 facelift premiere. Basically, when I put it to go auto-up (pull the switch up to highest point), sometimes the window will not fully close - it'll stop someway short and then come back down a little bit and then stop. I can fully close the window by pulling the switch half-up and holding it until the window fully closes.
It's been suggested that it might be the channel needs to be lubricated. I've had a look at this and it seems fine. I've also tried to reset the window by pressing all the way down and hold for 3 secs, and then fully up, again hold for 3 secs. I had to to this the other day when I disconnected the battery.
Whilst in neutral, the window auto-up feature works correctly.
The problem has been puzzling me for a long time now and recently someone suggested to me that it mght be normal behaviour and the trouble is I can't remember if I've always had the problem or not since it's been so long!
I noticed last night that I can get the auto-up going window to stop by pressing the accelerator whilst moving (i.e. in gear). So.. would anyone be kind enough to try this out for me and report back in the thread if accelerating whilst using the auto-up feature on the driver's power window causes the auto-up to cancel and stop?
Here's some of my tests so far:
Basically, window all the way down and then pull the switch to the second state to activate the auto-up and while the window is going up:
1) Key in position II on ignition, engine off.
2) Engine started, in neutral, stationary (not moving), accelerator not pressed (basically in idle)
3) Engine started, in neutral, stationary (not moving), engine reved to 3,000rpm
4) Engine on, in gear, moving but accelerator pedal not pressed
5) Engine on, in gear, moving and accelerator pressed (in short bursts if possible and safe to do so)
FWIW, my results are:
1) Auto-up works and completes
2) Auto-up works and completes
3) Auto-up works and completes
4) Auto-up works and completes
5) The window will go back down a little and then stop
I'm thinking at this point it's either:
1) Dodgy earthing (I don't have an earthing kit - do you?)
2) Weak battery (My battery hasn't been replaced from new, but it still powers up first time everytime and I've not noticed anything amiss)
3) The acceleration is causing drain which stops the power window? So the alternator isn't providing enough? Or again, weak battery?
I'd love to get to the bottom of this as it's been doing my head in for ages!
Hi,
