Cough* Mercedes-Benz use fuchs as an approved supplier of oil, they even recommend them above some of their own branded oils (which also come from fuchs) I like to pronounce fuchs as ****s oils, makes the day go that little bit quicker!
Oh and I'm currently using shell helix purely because it's cheap!
Picking up some oil for my FN2 that i've recently purchased and just wanted to be sure this was the best/correct oil.
Done some research and seems Honda recommends 0W30 Castrol Edge. But have also seen people saying 5W30 is better?
Is this the right stuff?
Click
cheers
Spot on - I presume you took oil samples and had them analysed? Or you're saying that because your engine didn't blow up when you used it?Is Shell Helix 5w 40 still acceptable in the Fn2. Bargain at under £20 for 5 litres
may venture to Fuchs Titan race S though as only ever tried Fuchs Super Synthetic and it was spot on.
Shell is perfectly fine.
