Rattle solution
Evening troops. As in the few civic flaws thread above my ep3 has developed the heat shield rattle behind bulkhead. As its out of warranty is there any solution i can do to this myself?
Cheers stuart.
Simple - remove the heatshield altogether. Doesn't take long at all (3 bolts IIRC).
Also before you start just make sure its not the i-VTEC cover. Get somebody to rev the car a little whilse you listen around the engine bay. If its the i-VTEC cover it can be solved by simply placing a couple of washers under each of the mounting points.
