Okay, Is it easy to remove the old ecU?
Found this on ctro
Are the plugs hard to pull?? Is it fiddly? Anyone got any tips? Worried I would chop something in the midst of removing the ecU..... Can I just unplug by pulling?
Found this on ctro
Aaron Coady said:gilberto said:Does anyone have a guide to removing the Kpro ecu? i remember someone posted a picture guide but i cant find it using the search function.
Help would be appreciated. :thumbup:
A screwdriver, 10mm socket.
Remove the cover underneath the glovebox
Use the screwdriver (FLATHEAD) to prise away the plugs from the ECU, There are 3 in total ... do not pull the wires, And becareful when prising away, that you do not snap or chip anything!
Open the glovebox, push the two corners inwards, and the glovebox will fall open.
Undo 10mm bolts - they'res 3 of them.
Done.
