Because this will flow better, and I already own it. It will take more work getting it fitted, but the results will be better. Even if I don't see fantastic results straight off the bat, it has lots of scope for future engine modifications. I had a Tegiwa manifold, and sold it before I fit it when I found out it was a blatant TODA copy. I'm not loaded or on a hippy crusade, but I refuse to help lazy companies that just want to ride other people's rnd and massively undercut them. Two-bit companies copying HOTSHOT SR20(where I've come from) manifolds killed HOTSHOT, and then there were no more advancements in design, because nobody wanted to put the rnd effort/cost in to it. That's a whole other topic though. ;p
As for suspension, you're right, but the only piece of the suspension that's 'in the way' is the arb. I have enough clearance below the manifold to run a straight across bar, someone else might have done the same thing.. I can't be the first idiot who wants more space where the arb humps over the exhaust.
