Had the car only 3 months and have already had to change the clutch, a lower arm ball joint and a track rod end so im hoping this isnt an expensive problem
The slight tapping sound can be heard at idle and only happens when the engine is fully warmed up (does not do it when cold), ive had the bonnet open and had a listen to see if it was the valve clearance issue but cant here anything, i can only here the noise from inside the car?
It only started to happen after i had an oil change done, upgraded from 5W-30 to 5W-40 oil, probably wont have anything to do with the problem but seems strange that the car was fine before hand
Any ideas?
Any ideas?
