Hi,
I have an intermittent squeak / squeal coming from something steering related. Doing some Googling points to a common issue with the steering rack which sometimes was swapped under warranty or other people have done some DIY jobs with grease.
Can anybody shed any light on this common fault and if there's anything I can do/get done for £100 or under? The best bit of info I think I have found is this:
"i've heard that you can put a small hole in the side boots and spray white lithium grease in there and it should subside the creaks... it's the guide that slides back and forth on the shaft inside that wears out and causes the creak from lack of lubrication... try that before blowing several hundred dollars on a new rack... "
Has anybody done this?
Cheers.
Cheers.
