milano_chris said:Cragen had 300 wbhp.
hovblackctr said:milano_chris said:Cragen had 300 wbhp.
no mate that was @ the flywheel, about 245wbhp.
G said:I would not go much further than you are tbh m8. It is not just about weather the engine will fail now, but what about in the near future. Any big power mods should be mated with a strong bottom end. Also depending on what rev limit you are planning on using you need to think about the valves. You also will need to think about oil cooling (very important).
I't is ok for tuners perhaps to push an engine super hard because if it goes pop it is perhaps not such an issue as if your baby goes.
I am not saying not to go for it, just try and be thoughtfull. It is a strong engine, but also has some super fine tolerances.
If it was me I would think about lowering the compression ratio, sorting some kind of charge and oil cooling out. The OEM pistons have a few special features so getting better items are going to be hard.
Maybe lightening the car and going for (if you havent allready) uprated brakes and trick chassis? Then you can just outbrake everyone .
Just my 2pnce worth.
Friendy said:G said:I would not go much further than you are tbh m8. It is not just about weather the engine will fail now, but what about in the near future. Any big power mods should be mated with a strong bottom end. Also depending on what rev limit you are planning on using you need to think about the valves. You also will need to think about oil cooling (very important).
Plan for spring next year is to increase the capacity and lower the compression and cool the oil, just wondered if I could fit the cams now, to spread the cost, cheers for all the help
G said:I may be wrong here, but, TP is not the IP cams the only ones out for use with F/I?
tp said:G said:I may be wrong here, but, TP is not the IP cams the only ones out for use with F/I?
There are Crower ones available as well. I'm not going to start a big bunfight but all the information is on CRSX.......... :wink:
typerkid said:If your going to do it, then you had better line the block.... but my new tuner has got no confidence that or with anyone in the UK can line a Honda K series.....
typerkid said:The FI crower cams, caused a RSX owner who tried them on his with a JRSC had nothing but trouble......
I wouldn't buy any cams until I knew that they worked for the FI route...
Just my 10 pence worth
Mike
Friendy said:typerkid said:The FI crower cams, caused a RSX owner who tried them on his with a JRSC had nothing but trouble......
Mike
Would you care to share your tuner
Not atm.... sorry his busy and is about to launch his own company selling lots of proven packages to all Honda owners... not sure on the timing, but it shouldn't be much longer...
Tarticus said:Not atm.... sorry his busy and is about to launch his own company selling lots of proven packages to all Honda owners... not sure on the timing, but it shouldn't be much longer...
Finally we will find out who this mystery tuner is, should be interesting, can he line a block by the way ?
Just asking as I may go for cams later
