Evening Chaps
Maybe bit of a vague request but if anybody can help I would be happy.
My CTR has developed a stronge metallic noise at around the above mentioned RPM range, Its not the heat shield on the drive shaft i've had this off already and had it fixed, its only when the engine is under load, if the clutch is dipped it stops, and it also does it if you sit with the car stationary just holding the car at the revs
It does not sounds like an exhaust rattle its more of a screech? But doesn't sound like a loose belt etc? Any idea? bearings, pulleys?
I know I haven't given you much to go on but any help would be appreciated as myself and my mechanic friend cannot work it out without throwing loads of money at it in trial and error
Thanks guys
Thanks guys
