Washer jet advice *warning boring thread!!*
Hey guys sorry for boring thread but need a little advise on washer jets.
Mine are lame I've owned more powerfull water pistols!! I've read that people change there CTR ones for Jazz ones, is this styling or power reasons? What other mods could be done to make them more effective?
Hope someone can help,
Have you tried cleaning the little check valve where the hose splits into two under the bonnet, that can block up easily.
As for Jazz jets they spray in a fan pattern instead of straight jets but if your system is block it isn't going to be much help.
Ok cheers for that I'll have a look when I do the weekly wash. Thanks.
If I wanted Jazz washers where would be best place to buy?
You need to carefully prise it open, there is a little rubber diaphragm in there, don't lose it or it won't work anymore. :p
If that's not block the jets could be so just pull the hose off them and unclip 'em. Then you can flush them backwards with a hose pipe or even under a tap.
Your honda dealer of course. ;)
