I have obtained a second hand Kpro.
So last night I fitted it. I put on the base map as per K manager. Also ticked the flash EML on knock.
I started it up and all was ok, idle was a bit lumpy in comparison to the stock ECU. When I started to drive, the car felt very lumpy, lack of power, kinda retarded ignition. The EML light would flash on and off. Error was cylinder 1 issue.
I stopped, put on a New map. I now put on the RSX map, changing ECU type to 2.
This was as lumpy it with a new error code: the VSS was found to be inoperatable.
I have no idea. what the problem could be.
Anyone come across a similar problem?
It was like it was either under fuelled or retarded timing. But I am no mechanic.
However, I thought these were generic maps that can be put onto a stock car.
The Kpro/ECU is from what I believe a pre face and the my car is a 55 premier.
Should that make any difference?
Only mod is a tegiwa M intake.
I am stumped to say the least!
Any ideas? Can anyone help?
