I originally made this thread back in May 2008, but I think it was lost due to the forum crash. As there are a few topics relating to hard baked on dust etc... I thought I would re-create it;
On my OE DC5 alloys, I felt they were letting the car down with the dirt on the inside face of the wheels. Last week I had the wheels off, and gave them a good clean, but most of the dirt (tar spots, baked on brake dust etc...) remained on the wheel.
So on Tuesday this week, I ordered some Autobrite Alloy Xtra from http://www.autobritedirect.co.uk/
It was £8.80 plus delivery for 5L. For ease of use, I also ordered a trigger bottle as well. It is normally used at a mix of up to 20-1, so the 5L goes a long way!
Now as the light was fading fast this evening, as I decided to try it out at 8:30pm, I only quickly tackled one wheel;
BEFORE
Now I decided to try the product out at 1-1. After leaving it for 2-3 minutes, I wiped it off with an old sponge, and rinsed thoroughly with water. Results were amazing for such a quick test, as can be seen below;
That was purely from using the Alloy Xtra, water and a sponge. Later on in the weekend, I will probably remove any remaining tar spots etc, and seal the wheels with wheel sealant, as the product is acid based.
I would recommend you use gloves etc... when using it in a strong mix ratio. Also when using it in a strong mix, I would recommend removing your wheels. Below is a pic where I oversprayed onto the rear caliper when I was testing it with the wheel on;
As you can see, it has stripped the corner of the caliper clean, so I would not want to leave any overspray on areas other than the wheel.
So far I am very happy with the product - To think I was maybe considering a refurb of the wheels, this has definitely changed my mind, and for around £10, you get a lot of product.
DONT FORGET THIS PRODUCT IS ACID BASED - SO USE ACCORDINGLY!!
Developed primarily for the transport industry for the fast and effective cleaning of wheel covers and rims.It provides good foaming,corrosion inhibition and wetting properties,dissolving grime,break dust,scale,oxides and carbon deposits.. THIS PRODUCT IS BLUE IN COLOUR AND
BEFORE
