Mine where fitted nearly 3000 miles ago, so im guessing what im hearing could be something different as it does sound like you have the problem described by neilly03
Yes the shims will fit any pad as long as it's the correct pads for the car. You need 4 plastic shims and 2 metal ones. Every pad has a plastic shim and then the pads on the piston side have a metal shim inbetween the plastic shim and the piston.
Cheers mate, given the fact the DS2500 currently does not have an outer shim or any shims at all (ie I can see the DS2500 logo on it), would it be an issue if fitted it with one plastic shim missing??
ie the squealing stems/stopped by the metal shims??
what do these plastics shims do?
