Chief said:lol who you going to rope into doing this for you Stu. :wink:
Its fairly easy if you can snap connect the ecu rpm wire, plus you've got power and ground already as haven't you got a terminal block thats hardwired into the cig lighter?
Positioning I've got mine on the steering wheel column although I may move it. :wink:
Chief said:I'm soldering my wires on the weekend Carl as the snap connector failed.
N77 said:Chief said:I'm soldering my wires on the weekend Carl as the snap connector failed.
Your best to solder them on as the snap connectors are too big for how much room you have, also alot better connection.
Try that
Carl
Chief said:Don't tell me your fitting this yourself Stu.
clem said:I take it you want a hand with this on saturday Dotty ???
dotty said:Ok we have encountered a problem :shock:
Its all wired up however the RPM signal on the wiring diagram N77 posted is different to the actual layout.
We have power and can mess about with the settings when the ignition is on, But when the engine is running and you go past the 'lowest' point and the 'shift' point the lights do not illuminate.
Can someone confirm which is the RPM signal wire?
Cheers.
