Home
Results 1 to 9 of 9
Thread: Removing rear subframe bar in engine bay behind engine
  1. #1
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    723
    Default Removing rear subframe bar in engine bay behind engine
    https://www.lingshondaparts.com/part...ckref/B__4800/
    Hi guys , Iím thinking of removing the following part so I can replace with new or clean up and repaint listed on lings Honda ( above link ) itís part number 9 which is the front subframe bar behind the engine, mines looking pretty rusty and in bad shape,
    Has anyone removed or replaced this? Is it hard to do? I can see thereís two large bolts either side but is there also some small bolts holding it to a heat shield too?
    Any help would be much appreciated,
    Thanks in advance.
  2. #2
    beankp60's Avatar
    Join Date
    Dec 2014
    Location
    Workington
    Posts
    135
    Default
    These do seem to rust pretty bad. if I was planning to replace it I would give the bolt heads and area around them a good wire brush to remove loose bits and give them a good soak in wd40/rc90 ect, maybe even spray them a few times leading up to when you are planning to start the job.
  3. The Following User Says Thank You to beankp60 For This Useful Post:
    Ricki1985 (04-04-2019)
  4. #3
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    723
    Default
    Yeah I was going to start spraying them this weekend with wd40 and soaking them a few times before removing In a couple of weeks.
  5. #4
    beankp60's Avatar
    Join Date
    Dec 2014
    Location
    Workington
    Posts
    135
    Default
    Yeah, Hondas love to snap bolts so I wouldn't take any chances.
  6. #5
    stu1873's Avatar
    Join Date
    Sep 2007
    Location
    bonnie scotland
    Posts
    2,188
    Default
    I removed mine last year due to refreshing my steering rack slider and inner/outer track rods. It was a bit rusty at either end but there were no holes in it due to rust so i just gave it a scrub with a wire brush and a coat of paint on either end then put it back on. The heatshield is also bolted to it in the middle of the bar.
    I will say that where the heads of the bolts for it were packed full of dirt and grime on both sides. I actually struggled to find the bolts at first and it took me longer to get it all out just to get a socket on them than it did to remove the 4 bolts. I had to use a bolt extractor on the heads for two bolts on one side due to rust but the threads had no corrosion on them so the came out easy enough.
  7. The Following User Says Thank You to stu1873 For This Useful Post:
    Ricki1985 (06-04-2019)
  8. #6
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    723
    Default
    Im thinking of investing in a decent battery impact wrench / driver , as I do a lot of work my self and the bolts are always a nightmare to undo or end up snapping. It’s All part of owning an ep3 I guess
  9. #7
    stu1873's Avatar
    Join Date
    Sep 2007
    Location
    bonnie scotland
    Posts
    2,188
    Default
    I also do 90% of the work on my EP3 myself and i think i have only had a couple of small 10mm bolt heads shearing in the 11 and a half years working on it. Rounding off bolt heads due to rust is the main problem i have had recently.
    Not sure on the best makes of impact drivers but milwaukee get good reviews. The right angled drivers look ideal for working on the motor.
  10. #8
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    723
    Default
    I agree rounding the heads is the common problem. I will check out some reviews on the impact drivers and will probably buy one. Cheers
  11. #9
    beankp60's Avatar
    Join Date
    Dec 2014
    Location
    Workington
    Posts
    135
    Default
    Quote Originally Posted by Ricki1985 View Post
    If you haven't got a good sized compressor and are looking at battery ones I can recommend the Ingersol rand 1/2" battery guns. I've had mine must be about 4-5 years now and its a beast. I can only remember seized s2000 front subframe bolts it couldn't get out and they were well in there! I've heard the Milwaukee ones are good but I've not actually used them before. They can be expensive but they are a time saver and I always thought after I completely rebuilt the rear suspension setup on my Celica GT4 that it had earned back what it costs after that job.
  12. The Following User Says Thank You to beankp60 For This Useful Post:
    Ricki1985 (08-04-2019)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
