Home
Results 1 to 7 of 7
Thread: After radiator and coolant change major problem, please help.
  1. #1
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    632
    Default After radiator and coolant change major problem, please help.
    I’ve changed my radiator and coolant today as I had a small leak on the radiator. Everything is back together and just like before however Ive come to fill with coolant and filled via the radiator cap like most people recommend and now gone to start the car to let it warm up and release any air. However the car reached temperature within about 2 minutes and the fan came on but stays on and doesn’t switch off. The radiator cap is off and there is a huge amount of air keep bubbling out. Could this just be a case of an air lock / allowing more time to let the air out? When I turn the engine off with just the ignition on the fan runs for about a minute then clicks off. Any help would be greatly appreciated. Cheers
  2. #2
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    632
    Default
    If anyone’s interested? I sorted this problem. For anybody experiencing a similar problem after changing your radiator or coolant then the problem was a massive air lock. After 4 hours of trying different methods to get rid of the air including draining the coolant and starting again, i thankfully got it clear. Everything seems perfect now.
  3. The Following User Says Thank You to Ricki1985 For This Useful Post:
    mike.h (05-07-2019)
  4. #3
    mike.h's Avatar
    Join Date
    Oct 2016
    Location
    Horsham, West Sussex
    Posts
    1,803
    Default
    Good to hear you got it sorted! Thanks for the update.
    Subaru Leone | EF Hatch | EG4 VTi | Rover 214Si | EK | BB5 | EP3 | EP3
  5. The Following User Says Thank You to mike.h For This Useful Post:
    Ricki1985 (05-07-2019)
  6. #4
    Vitka's Avatar
    Join Date
    Jul 2018
    Location
    Eger, Hungary
    Posts
    226
    Default
    I'm sad I haven't come across this topic earlier. Bubbling is quite normal, when changing the coolant, considering you see no smoke in the radiator. I've heard, that in EP civics in general, it's a good idea to lift the front a bit, when trying to get the air out after a coolant change. It produces better results quicker.
  7. The Following User Says Thank You to Vitka For This Useful Post:
    Ricki1985 (06-07-2019)
  8. #5
    Hamza Type R's Avatar
    Join Date
    Feb 2015
    Location
    Nottingham
    Posts
    1,139
    Default
    Quote Originally Posted by Ricki1985 View Post
    Which radiator did you go for mate?
    Premier Edition EP3 2005...Mercedes Benz C220D
  9. #6
    Ricki1985's Avatar
    Join Date
    May 2014
    Location
    Lincoln
    Posts
    632
    Default
    I was going to go for the Tegiwa aluminium radiator at 1st but they were out of stock everywhere 10 - 15 days delivery, I was in a bit of a rush , so went for the M2 aluminium radiator instead and it’s spot on. Can’t fault it. Good quality, good price and fitment was perfect too with OEM fans ect. Would definitely recommend the M2 Radiator.
  10. #7
    Join Date
    Feb 2015
    Location
    Nottingham
    Posts
    1,139
    Default
    I went for the Tegiwa radiator didn't come across M2 radiator
Posting Permissions
  • You may not post replies
  • You may not edit your posts
