Drove the ep3 yesterday vtec in 1st gear and the EML started flashing for 5 seconds wonder what happened there?
I believe that means the engine is experiencing misfires, be careful.
What plugs? Torqued up ok? Coil packs on ok?
Hmmm. Think I'd get a code reader on it.
I've not got the car mapped,it's standard far as I'm awareIs it mapped with Hondata?
Same as Chris, has it been mapped and the EML is acting as a shift light? I'd try get a code reader plugged in to see if any codes are there.
No, it's your knock sensor detecting knock otherwise known as detonation. Sometimes it's a faulty sensor, or it could be knock.EML came on today P0325 Knock sensor bank 1
Is this related to the chain?
Knock is pre-detonation which could be lots of things. Usually on a k20 it's timing, or fuel, but more often than not a faulty sensor.I did compression test all 4 cylinders show 180ish
I'm not sure what could it be,does it need valve clearance doing?
