Home
Results 1 to 7 of 7
Thread: T valve mod
  1. #1
    Xplicit's Avatar
    Join Date
    Aug 2019
    Location
    Scotland
    Posts
    269
    Default T valve mod
    Hi guys
    Has anyone done the t valve mod on the fk2?
    I know the part they use is fitted to the fk8, and I'm looking for feedback as to the benefits of doing it, some say more boost but I've not seen any figures to backup the claim. Some say it's to counteract loss of boost
    I'm old school in my way of thinking if it ain't bust don't fix it. But I've read of quite a few that has done it but without the reason why. The parts themselves are only 15 quid from tegiwa, although I hear you need the hands of a 10 y old school girl to do it as it's very tricky to get to. but I'm thinking if it was an issue with the fk2, hence the reason for them fitting it to the fk8 then should there not have been a recall for it?
    I see the kit has 3 bungs which effectively close off 3 pipes in the process which is the biggest factor in my not doing it yet as I'm not sure if any damage could be done by this
    Championship White Type R GT FK2 , Tegiwa B Pipe, Remus Responder, Pipercross, Climair
  2. #2
    AndyDay1971's Avatar
    Join Date
    Dec 2016
    Location
    wiltshire
    Posts
    42
    Default
    I have done it ,once you get bulkhead panel out its then easy
    You are right why do it if not broke also for 15 why not then you wont have any worries
    I don't think there were any performance gains but I thought it picks up better so maybe mines was getting faulty and also on 2 occasions I had little or no boost
    Blanking pipes will not damage anything!!!!!!
  3. The Following User Says Thank You to AndyDay1971 For This Useful Post:
    Xplicit (17-05-2020)
  4. #3
    gatecrasher3's Avatar
    Join Date
    Jan 2010
    Posts
    225
    Default
    I've done it purely as a precaution. It made no difference to the way it drives which is what I expected.
    I wouldn't bother messing about trying to do it without moving the scuttle panel as it's way too tight and given that the hose attachment to the inlet manifold is plastic it could easily be damaged if you're heavy handed.
  5. The Following User Says Thank You to gatecrasher3 For This Useful Post:
  6. #4
    Xplicit's Avatar
    Join Date
    Aug 2019
    Location
    Scotland
    Posts
    269
    Default
    Thanks guys, so it's more of a failsafe mod then? I've not read of any actually failing so far so just wondered why everyone was doing it, as it dosent appear to give gains.
    I have read an article on hendys I think that it will fail in time, although that may just be a marketing ploy to sell the kit
    Its just the thought of blanking off pipes that are there for a reason made me wary
  7. #5
    MB CTR's Avatar
    Join Date
    Oct 2015
    Location
    Cornwall
    Posts
    173
    Default
    you need a cheap hose connector and a cap or like I did a bolt, no point spending 15 quid on a 'kit' and its its a preventative mod (unless the valve has failed). but yes its a bit of a **** of a job, I struggled to get my hands in there and the pipes were on tight.
  8. The Following User Says Thank You to MB CTR For This Useful Post:
  9. #6
    LK's Avatar
    Join Date
    Oct 2019
    Location
    Finland
    Posts
    7
    Default
    I do this mod my car, i think car makes boost litle fast now. Spray wd-40 etc. In hose joint that helps when you take oldhose off
    FK2 TYPE R -16. Turbotec remap. Fox 3 b-pipe. K&N airfilter. T-valve bypass mod.
    365hp/525Nm
  10. #7
    veehexx's Avatar
    Join Date
    Jul 2018
    Posts
    417
    Default
    i'm on the belief it's a preventative measure for when the t-valve fails (which affects boost).
    i was planning to do it when i had the scuttle tray off for fitting oil catch can but couldnt get the bits in time so not bothered.
    worth doing/knowing about for when it fails or you have to go down the back of the engine for whatever reason. i wouldnt bother do it if it's your only job down there.
    FK2R Mods: Remus cat-back, Remus Responder, K&N Panel Filter, Girodisc 2peice discs, Carbone Lorraine RC6e Pads, HEL oil cooler, TDI-North Intercooler, HCTR Brake Cooling Ducts || Audio: stock + Audison APBX10DS sub || Summer: OE 19" wheels, 255/35r19 PS4S & Cup2
  11. The Following User Says Thank You to veehexx For This Useful Post:
    Xplicit (18-05-2020)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
