G
A veritable chap
Updated post as a lot of images have gone as my old hosting sight went kaput. Anyway here she is as she now stands.
I have Just had a new motor put together by a tuner over here called TDI North based in Warrington. With a lot of help and advice from the guys at Skunk2 racing.
The spec:
EXTERIOR
Re painted in and out Fiat 500 Campovolo grey. Using Lesonol paint
Buddy Club Carbon Bonnet
De badged (well the Honda one anyhoo)
Pressed steel no plates, old skool yo.
CHASSIS
Rota Grids. 17x9 and 17x8.5
Yokohama Parada Spec 2's 205x40x17 and 215x45x17
TPI Racing Lug nuts
Tarox 6 pot callipers, F2000 disks and Rallye pads
Goodrich Hoses
E-Tech strut brace
AST Coilovers. Fast road set up.
Camber bolts front,
Skunk2 racing adjustable arms rear.
Skunk2 LCA's anodized gold
JDM ARB
Skunk2 lower tie bar
ENGINE/DRIVE TRAIN
K24/20. Blueprinted bottom end, Forged H beam eagle custom rods, Custom Pistons with valve pockets.
Valve Train:
Skunk2 Stage 3 cam shafts
Skunk2 Pro Series Valves
Skunk2 Pro Series Springs, Titanium retainers and seats.
Skunk2 TCT.
Skunk2 K Series Inlet manifold.
Skunk2 Composite Fuel Rail
Skunk2 70mm Throttle body Black series
DC Sports Header.
Skunk2 70mm Mega Power exhaust
Speedstar Racing Aurora Rocker cover
ARP Head studs.
ARC Airbox
Samco hoses
Competition Clutch Clutch and flywheel
INTERIOR
Caged 6 point roll cage in red
Takata Harnesses
Buddy Club Seats
KEY!S Racing steering wheel
Works Bell Rapfix QR Hub
STRI Oil temp and pressure gauges
Skunk2 gear knob
JDM Carpets
Sparco Pedals
D.R.E Shiftlight
Alpine headunit.
So there you are. The motor is running a 25 deg cam gear that we will be swapping out for a 35 or 40 maybe. So should yet still see some decent power increases.The motor is amazing though, with 190flbs of torque in at under 3000 revs the car is so drivable. Rev limit is set at an easy 8200 at the moment. The motor has been built to take a lot more and once we have the new gear in we will probably re set that at around 8.6-8.8k.
Also going to paint the rims red as I think they will look a bit more saucy.
Thanks to the guys at TDII North. Tony and Aaron at Skunk2, Eric Moon, Cristian Loza, Roy and Marin and everyone else at Cinibeat. The cars build is followed every month in Fast Car UK. (where I work).
The spec:
EXTERIOR
CHASSIS
TPI Racing Lug nuts
Goodrich Hoses
E-Tech strut brace
Camber bolts front,
JDM ARB
ENGINE/DRIVE TRAIN
Valve Train:
Skunk2 TCT.
DC Sports Header.
ARP Head studs.
ARC Airbox
Samco hoses
INTERIOR
Takata Harnesses
Buddy Club Seats
Skunk2 gear knob
JDM Carpets
Sparco Pedals
D.R.E Shiftlight
Alpine headunit.
