Hi guys, my clutch has just began to squeak, anyone had tha same prob? any sugestions on how to get rid as is quite annoying. Regards, G
It's the clutch pivot point most likely...it can get worse until the pedal feels a bit "grindy". Can either be the slave cylinder piston or the release fork, pivot point...or both. You can unattach the slave cylinder piston from the release fork and clean/grease it up, and you can access the inner pivot point through the rubber bung and "very" gently add a drop of oil or a dab of grease. I've been doing mine every 6 months or so for years, just gets dry after a while.
