Home
Results 1 to 9 of 9
Thread: Made to look like a fool...
  1. #1
    tollanfn2's Avatar
    Join Date
    Feb 2014
    Posts
    24
    Default Made to look like a fool...
    Had my car now for 3 weeks and after the first couple days I noticed that in the morning there is a creeking/knocking noise coming from the back suspension area on both sides but it only lasts minutes and goes away, I took it back to the garage yesterday and they checked it and came back to me and said are you sure is isn't the road at your house or something in your boot! I'm
    Sure I've seen this as a common problem before could anyone verify this? Thanks in advance
  2. #2
    NYA's Avatar
    Join Date
    Nov 2006
    Posts
    19,172
    Default
    First thing I'd look at is the Top Mounts on the shocks. If they are loose they will cause a knocking noise.
    Trolling for the Lolingz since 2006
  3. #3
    Site Treasurer Loxy's Avatar
    Join Date
    Jan 2009
    Location
    Lancs
    Posts
    29,350
    Default
    Rear creak is a common issue. I'll dig out the service bulletin and host it, give me a sec.
  4. #4
    tollanfn2's Avatar
    Join Date
    Feb 2014
    Posts
    24
    Default
    Thanks lads
  5. #5
    tollanfn2's Avatar
    Join Date
    Feb 2014
    Posts
    24
    Default
    Whilst we are here what about the tapping noise coming done the revs after being in vtech? Just normal? Only done it to my ears a couple times
  6. #6
    Join Date
    Jan 2009
    Location
    Lancs
    Posts
    29,350
    Default
    When were your valve clearances last done? They should be checked every 25k miles. It could also be the injectors, they are quite noisy on the FN2.
  7. #7
    Join Date
    Jan 2009
    Location
    Lancs
    Posts
    29,350
    Default
    Bulletin, print it out and take it back. Only covered under normal warranty though.
  8. #8
    tollanfn2's Avatar
    Join Date
    Feb 2014
    Posts
    24
    Default
    It's an 09 plate on 48k miles mate full honda service history but I'm not sure about the value clearances
  9. #9
    tollanfn2's Avatar
    Join Date
    Feb 2014
    Posts
    24
    Default
    Thanks for that it looks a very simple fix and to be made sound like an idiot as if there something in my boot moving around is just insulting as per from a dealer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
