Lottie
The Duchess
Tools/Equipment required:
2. Move further down on the right hand side and pull towards you.
3. Move to the left and do the same again.
4. The surround should now be released and can be removed.
5. Three screws now require removal (bottom left, bottom right and top centre.
6. Remove the screw on the bottom left.
7. Remove the screw on the bottom right.
8. Remove the screw top centre.
9. Tilt the console forward.
10. Remove the connectors.
11. The console should now be free to remove. Remove the bulb as necessary by turning roughly 90 degrees.
12. Replace bulb with P/N 35505-SA5-003.
13. Replace parts in the reverse order, job done.
Thanks to Si for the model hands :lol:
- Phillips screwdriver
- Replacement bulb P/N 35505-SA5-003 (x1 bulb £4.42 at time of writing)
