Everything installed but there's a thumping noise coming from the rear left coilover. I think I'm going to have to take it down and see if the preload setting is correct as it sounds like the spring is losing contact with the shock mount. Other than that the car rides quite nicely. Currently have it set to the softest settings at the rear (until I get the thump sorted) and about 5 clicks from soft on the front but even now I can feel the difference over my previous Neuspeed Koni/Tein SS spring setup. Turn in is much sharper and the general feel of the car is so much better. Outside of the low speed thump all of the clunking I used to have with the Konis is gone. My only 'disappointment' is that the rear of the car isn't as low as I hoped it would be and I'm at the lowest setting but I still have to wait and see how it 'settles'. I'll post some pics in a week or so.
If anyone had a similar thump I'd appreciate your input if you found a solution.
Regards,
CL7-R
Pre-load adjusted...problem solved...rides like a dream...
CL7-R
