Hello all, have been a browser on here for a few years now with little input so though I'd share...
This is my second DC2, the first I had around 2013 for about a year, should have kept it as it was much cleaner than this one autocar wrote a to buy or not to buy on my for sale advert too
https://www.autocar.co.uk/opinion/motoring/buy-or-not-buy-1997-honda-integra-dc2-type-r-4599
I got this DC2 in 2015, used it daily for about 3 weeks then it sat in the garage until the end of last year, its fairly tidy bar a couple of car park dings.
The aim was to make a trackday/weekend car, so nothing too extreme!
A few pictures of the car before any work was done, underside components were in bad/average condition for their age but the shell wasn't too bad, no major rust/rot just surface.
4E5F37AF-584B-4616-9EB0-E9CF718B926E by Adam Richardson, on Flickr
B721203F-3A20-4EF0-AE9D-91C0116DFADE by Adam Richardson, on Flickr
37B07561-C6D6-4763-B2BE-CAD0A62BACAA by Adam Richardson, on Flickr
485B957A-9680-45A9-9C18-5B36C19DA2A1 by Adam Richardson, on Flickr
1BA7F64E-0958-468E-B745-8233FB5CB26C by Adam Richardson, on Flickr
FF20A544-E682-46A8-91A0-4F67218E9316 by Adam Richardson, on Flickr
4F4699EF-B432-428D-8267-98E278978191 by Adam Richardson, on Flickr
5DB11EE9-3F51-4756-B09F-682B28544A52 by Adam Richardson, on Flickr
C5935F81-628D-42EA-A598-8A80B46C137C by Adam Richardson, on Flickr
16D3EAC1-F5C7-49B6-8096-A2AE0304CC66 by Adam Richardson, on Flickr
A5FC9125-321A-4480-98F0-14DF931B9E33 by Adam Richardson, on Flickr
0076D6B2-BA64-4867-BE1B-A34B5942A952 by Adam Richardson, on Flickr
F11E6226-9C4A-4522-BA9F-9769634F5A3E by Adam Richardson, on Flickr
02E8964E-9E92-4EA9-AB54-E8256B9E41A9 by Adam Richardson, on Flickr
CE2F46A6-8FC3-46B1-A59B-6C3CD66CF529 by Adam Richardson, on Flickr
466B36B3-C722-4D94-9D6B-493159E4A456 by Adam Richardson, on Flickr
D61710C4-4FF0-4072-8059-C7D242FCD708 by Adam Richardson, on Flickr
I had a couple of bits powercoated, front hubs, rear trail arms, roll bars and a few under bonnet bits…
F81952AC-BF13-4758-9952-44DAD8688062 by Adam Richardson, on Flickr
04E10835-0C36-4E4E-9D8D-306FC1998328 by Adam Richardson, on Flickr
720D63B8-C3C7-4FF5-9606-1436C50D83D8 by Adam Richardson, on Flickr
6F6DA81D-84D7-41EA-8DD9-249300A420F8 by Adam Richardson, on Flickr
I decided it was easier to buy new arms and wishbones etc complete with new bushes as oppose to re-bush and power coat the existing.
Started the build back up…
4A76A32F-EF36-47DE-991E-2069AE17B687 by Adam Richardson, on Flickr
Bigred brake re-furb
50A5C1A3-27DA-42F3-87D0-FFC07D7A5A6E by Adam Richardson, on Flickr
7E70C4F9-3B79-4673-BCCE-FE51E162EE56 by Adam Richardson, on Flickr
9A848F89-23C5-4612-8061-B6ACD62B8689 by Adam Richardson, on Flickr
3A80094F-385B-48E6-9444-8EDC40061270 by Adam Richardson, on Flickr
59563A8C-572F-4540-8625-210AD45D16C4 by Adam Richardson, on Flickr
390324FF-CA69-4C56-948E-5C50CE43BD13 by Adam Richardson, on Flickr
3ED905B8-F9E9-44E5-A34A-69732C932061 by Adam Richardson, on Flickr
BD1F50A4-67CC-400A-BD42-E471457E416B by Adam Richardson, on Flickr
Once id concluded messing about it went to Grinspeed for a full set up, box rebuild, new syn on 3rd and the 4th and 5th rations from a 96 spec box.
0563BFD6-C504-4F4A-B71C-90626B9C4960 by Adam Richardson, on Flickr
CEF867D1-4413-4BE8-96C4-4183FAF7080C by Adam Richardson, on Flickr
2027782D-DE5D-4E59-AF19-5B5191D66256 by Adam Richardson, on Flickr
Quick spec:
BC Racing Performance Coilovers BR Type RH (Pillowball)
Hardrace Engine Mounts Set
Hardrace Front Lower Control Arm (Pillowball)
Hardrace Rear Toe Control Arms Set (Hardened Rubber)
Hardrace Rear Upper Camber Kit (Hardened Rubber)
Hardrace Rear Lower Control Arm
Hardrace Front Compliance Bush (Pillowball)
Hardrace Rear Trailing Arm Bush (Hardened Rubber)
Honda 40/40 Brake Prop Valve
P/C Rear Trailing Arms
96 Spec 5th Gear
96 Spec 4th Gear
HEL Brakelines and Wilwood Bias Valve
Steering Wheel Spacer
Powerflex Exhaust Mounts
M2 Adjustable De-Cat
Engine Gasket set
98 Spec Manifold
Superstreet Performance Cat Back
Steering Wheel Quick Release B&G
Caliper refurb by BiggRed
Skunk 2 Front Camber Plates
Tegiwa Rear Alu Tie Bar
Hardrace Rollcentre Adjusters
Hardrace Tie Rod Ends
Ingen longarm intake and filter
Rocker Cover refurb
Should hopefully be at a circuit soon and the Ring in May fingers crossed
Adam
Quick spec:
96 Spec 5th Gear
96 Spec 4th Gear
Engine Gasket set
98 Spec Manifold
Rocker Cover refurb
Adam
