Morning All,
A collogue and I am currently in the process of making up a BBK with custom machined brackets for both an s2000 and an ep3
This post is NOT to sell big brake kits, but simply to gauge interest in affordable BBK using common 1 piece discs instead of higher cost rotors.
The kit I am currently working on to fit my S2000 and ep3 uses 330mm 1 piece discs with Aston Martin (Brembo) 4 pot monoblock callipers and Performance friction pads. The calliper piston area is similar to that found on other BBK's for the S2000 so will have a similar pedal feel.
Using a single piece common disc has a huge maintenance cost saving, costing around £200 for a set of discs and pads compared to £350+ for a new set of rotors excluding pads.
Current cost for the kits would depend on level of interest. Once testing and validation has been completed a group buy will be set up and spread across S2000 and EP3's.
1 Kit - £1750.00 (£1550 excluding Discs and Pads)
5 Kits - £1400.00 (£1200 excluding Discs and Pads)
10 Kits - £1150.00 (£950 excluding Discs and Pads)
20+ Kits - £1050.00 (£850 excluding Discs and Pads)
To try and make the kits more affordable, we have negotiated away the D&D and programming costs.
Still awaiting further confirmation from calliper supplier for 5+ kits, but can supply 10+ kits at costs below.
5 Kits : £ TBC awaiting confirmation from Calliper supplier - Estimating at £950
10+ Kits : £950 including Disks & Pads
Delivery circa £10
Kit includes:
Aston Martin Brembo 4 Pot Calipers (Black / Red / Silver)
330mm Single Piece MTec Discs (Choice of style) Option to add coating +£14
Performance Friction Z Rated Pads
Billet Machined Aluminium (Grade: 6082 T6) Brackets
Grade 12.9 Bolts
Spigot rings (ep3 only)
(All New Parts)
The aim is to make a kit at the price of the cheaper bbk's, but using higher quality parts.
1st Set have been installed on an s2000. 2nd set will be installed on an ep3.
Confirmation of spacer size to run OEM 17's should be confirmed later this week.
Please note, this is NOT a group buy, and simply to gauge interest prior to setting up GB.
Register interest to confirm numbers.
1 -
2 -
3 -
4 -
5 -
Any feedback welcome!
Delivery circa £10
Kit includes:
Grade 12.9 Bolts
(All New Parts)
1 -
2 -
3 -
4 -
5 -
