hi, use a voltmeter and check the voltage at the plug, do it once with the bulb in ( so there is a load on the cable) then once with the bulb out, do this to the other side and compare. ie 11-12 volts good,
if the voltage on the dodge side is alot lower, then this would be why. could be a broken wire. also check your earth continuity to the battery.
danny
