Bolts on the CAT
Chris.
Founder
Administrator
Can they be replaced? Or is it a case of replacing the whole cat?
EDIT
Sorry, should have added more detail - I mean the ones where the B pipe sits on to.
Yes, they are replacable. No need to replace the whole cat.
Did yours snapped off?
No, I sold my Spoon kit and took it of today. The bolts were a little rusted as well as the nuts so I treated them with a bit of WD 40. Managed to get the B pipe of but putting the OEM one back on was a hastle. I used new nuts but it started threading. Finally got it off and the bolt is all threaded. Got the old on on (just) but it's blowing slightly so I need to replace the bolt for when the Apexi gets here.
1 of my 3 Cat to B Pipe bolts are threadbare. :(
I am not blowing but I think the dork who fitted my FREE Dc Sports Exhaust managed to bend the heatshield as i get vibration/rattle @ low revs. :x
How easy are they replaced? I don't want my Apexi blowing :shock:
On the reverse side ie facing towards the cat there is a flat oblong metal plate. Is it a case of removing this with a flat bladed instrument? Or does it need to be banged through from thread side?
hi :)
i would hit the threaded end as they are spline fit , it may be wise to add a small amount of grease or copper slip to the new ones when refitting as it will be tight .
danny :wink:
More than likely it's the additional resonance from your sports exhaust that is causing the heatshield to vibrate more Scouse.
It sounds horrible though Paul, I need to eliminate it. :(
Get your car on a ramp - there are some bolts on the heatshield next to the silencer on the b pipe. I had this problem too and it sorted it out when I tightened them.
Scousefella said:
I will investigate @ the weekend - cheers Boss. 8)
No probs fella.
dannysed said:
hi :)
danny :wink:
What kind of grease should I use?
