I have worked in engineering for 24 years, worked on cars an bikes for longer and my best bet by the sound of some of the comments on here, know a lot more about how a clutch works and what causes them to fail.
Thanks for your very friendly replies, help etc bye....
If it's the bearing that has gone I can understand why the biting point would be low but I'm unclear while if the springs have relaxed how that can change the position of the pedel. Weak springs = slipping clutch.
£400 this time of year....O dear...lol. Cheers I will post what they say tomorrow.
See, here's the thing captain chaos....
It seems you actually know the square root of fvck all when it comes to clutches.
A failed release bearing will NOT cause bite point to be low.
Low bite point is failed pressure plate springs or worn friction plate. Nothing to do with bearings.
You also mention spring pressure on the pedal, where do you think that spring pressure comes from....
That's right, the pressure plate springs. No spring on the pedal...So if they are weak, and not fully returning, the pedal won't fully return either.
Clutches are an unknown entity when it comes to lifing. Just like the previous usage before you bought it.
Either way. As dotty has said, and so will I, average mileage is around 60kmiles for a clutch on these.
As are a lot of cars really. Not just Honda. Differing usage yields differing results. I see enough to know. Lambos usually need a clutch before 10k generally. More of your Flawed logic.
24 yrs of engineering does not an expert make.
Now pick your dummy up and don't embarrass yourself any more. Xxx
