Fire_2 said:i would if a charger would help my lap times :?
Forgot to add what sort of power would I get running at 9ish psi, or what would the max psi be on std internals
Tarticus said:Forgot to add what sort of power would I get running at 9ish psi, or what would the max psi be on std internals
Are u talking about a Turbo here ? If so you looking around 8psi ish on standard internals
You can get 450BHP though with not to much work that has been proven to be reliable.
speak to you know who I wont mention there names as ill get told off again, but its where I have my car tuned :wink:
If you go to there web site under Turbo Kits there is some information including some graphs with them running with CAT`s in place etc etc
CTR said:Paul have you considered changing to a Rotrex S/C instead???
It would certainly allow to gain more power and you could run with an I/C also :wink:
It's just a thought, as I know they are capable of producing a lot more power than the JRSC unit your currently running.
Friendy said:But it does not seem to produce the torque, this has been an ongoing point of discussion on ctro. Mine produces 261wbhp and 214ft, where the rotrex seem to produce inexcess of 320wbhp but only 230ft, if I remember, and you need to run it at 14psi
