Hello everyone,
let's keep things short: As I find prices on induction kits too high for what you get, I decided to take matters in own hands and build one myself!
I took the designs of a well known overpriced kit in consideration and started to make a prototype, based upon, not a copy or replica.
Let's go to work!
Using some basic materials as fibreglass, epoxy+hardener, aluminium foil, cardboard and tape, I started out of the nothing.
Here we see the filter (JC60/67 maxogen filter), a silicone T coupler and a mould. The aluminium foil is used to replace epoxy remover which is quite expensive.
Lightweight fibreglass, and yes, it IS lightweight @ only 225grammes/square metre making it almost equal to more exotic materials as kevlar and carbon fiber.
2 layers of fibreglass are used to make the prototype.
Here we see the first result of the prototype airbox, the actual result was a surprice as no vacuüm moulding was used! It was still quite smooth, more than good enough to continue the works.
Speaks for itself, the intake pipe, using same advanced technologies (cardbox, alu-foil and tape) I designed a 3" tube as intake.
Placing the pipe under 45° angle to clear several engine bay components,
Using a marker, a hand operated milling cutter, tape and a semi-round shape file tool, I made a hole, fitting the intake to the airbox.
Not perfect yet, but I'm pretty happy with the results so far.
The overall weight so far is 800grammes, and that's because the silicone coupler weighs 200grammes. If I had taken another filter with 3" coupler (my mistake there), the silicone T coupler wouldn't have been required, saving me 200 grammes and making the final result around 800grammes including ducting and clamps, making it lightweight like the carbon fiber type of box.
However, this is only a prototype and I'll try making a V2 in the future, making it even better, and perhaps making more of them if I could find anyone willing to buy one. I have enough fibreglass to build perhaps 8 more... so if anyone interested, please let me know
If anyone could provide me with some close up pictures of the real model, every angle, inside out and with measurements that would be helpful because I had to guess alot of the dimensions.
Now the bad news!
Because I go on holiday (the lady insisted!), I won't be able to complete this prototype within this month. First test should be done by the end of december.
Sure I'll keep you guys up to date.
UPDATE 17APRIL 2011:
Okay, after a long delay we finally managed to complete the prototype. It's appearance isn't that great
But it's a fully hand made, so that justifies for it's looks
Here we see the rough completion of the box
And below it's been fitted on the car.
Note this is not the final mounting, but we ran out of time and wanted to take it for a ride, so some tape and rope to fix it quickly!
Now what matters most: The performance!
*lightweight, weighing under 800grammes!
*Idle rpm was way too low at first, nearly stalling the engine, but after a few miles, seems the car has adapted to the changes, runs smooth now.
*Slight but feelable torque increase between 4000 - 5800
*Feelable more power from 6000 - 8000
*Throttle response increased a fair bit, making the car more aggressive, especially in vtec
*Power dip at vtec changeover almost completely gone, (didn't expect this one to happen!!!)
*No sound increase at all, except in vtec where the car screams a little more than before.
So, finally costing around 120£, I'd say it's worth every penny!
I'll try make a sound clip some day and will enjoy the power-dip eliminationn for now, until the car gets mapped
I'm curious what power to see on the dyno...
Note I have still an RBC to fit, but I'll leave that for later, right before mapping.
UPDATE 18 APRIL 2011:
Won't have dyno in the near future, but I can do a datalog using my OBDII scantool.
So I did, here's a comparison from two 3th gear pulls.
Started at around 30km/u and full throttle!
There clearly is an improvement in performance, car hits 30-100 a sec faster.
I did a 0-100km/u (0-60Mph) run at under 7sec (6.68 to be precise according to the log)
I wouldn't compare those 2 as they were very different circumstances.
Still I put them in graph...
A under 7sec is not bad I'd say.
For not wasting my tires, I launched at only 2300RPM.
Better times might be possible by launching higher
Souclip:
http://www.youtube.com/watch?v=uXWCX1mZ3lY
Let's go to work!
Now the bad news!
Souclip:
