Here is my 1998 Integra Type R Turbo mods list:
* Act Stage 3 Racing Clutch
* Apexi N1 Catback
* Slotted Brembo Rotors
* TN Suspension
* Stabilizing bars
* After market spoiler
* HID head lights
* Compustart Starter and Alarm
* B&M Short Shifter
* Aftermarket Stereo
* Timing belt and water pump recently replaced
* Garret T 28 Turbo. Custom Turbo that was especially built for the car. Running at around 10 pounds on pump gas 91 oct
Turbo charger Garrett T-28 A/R 48 (up to 22 psi output)
intercooler 18"x2.5"x9"
turbosmart blow-off valve
blox turbo manifold
tonaka intercooler
polished aluminum charge piping
k&n cone filter
custom downpipe
customo oil return line
stainless braid oil feedline EARLS -3
JG oil feed adapter
oil filter
oil 10w30 4L
90 deg fitting (x2)
custom flanges to adapt turbo
custom turbo housing bracket
2.5 flex pipe
FMU Blox
map senso adapter (BLOX)
wahlboro high flow fuel pump 255lph
fuel line
vacuum T-connector
boost gauge
air/fuel ratio gauge
exhaust manifold gasket
02 sensor bung
PCV valve filter (k&n)
b&m fuel press gauge
b&m fuel press regulator
fuel filter
jackson racing ignition
* Apexi N1 Catback
* TN Suspension
* Stabilizing bars
* HID head lights
* B&M Short Shifter
blox turbo manifold
tonaka intercooler
k&n cone filter
custom downpipe
JG oil feed adapter
oil filter
oil 10w30 4L
90 deg fitting (x2)
2.5 flex pipe
FMU Blox
fuel line
vacuum T-connector
boost gauge
02 sensor bung
fuel filter
