I'm having a problem getting the 30mm nut in front of the Rack Slider undone. Any suggestions? It's just really tight and as space is limited I can't really get much leverage on the big nuts. Any suggestions guys?
I have some shorter (25mm) Steering Arms by Hard Race as replacements. This is so I can get add more Camber and lessen the Toe In. At the moment the Toe In is set at 8mm with Camber at 3 degrees and Caster at 2.4. I need up to 6 degrees of Camber with the Toe a lot less. Bit of a hairy ride.
