Hi,
Purchased a EP3 and has EML on. Seller stated that he fitted decat after k100 was fitted and paperwork confirms this.
Do i need a new map?
Thanks in advance
Ideally you need a remap to account for the decat, though turning off the 2nd O2 sensor - which is likely throwing up the EML due to perceived lack of cat efficiency- is just a tick box in the Hondata config. As it's a K100 you will need a mapper to do that for you anyway so might as well get both done same time.
Might be worth getting a code reader on it anyway just to confirm, at least then you'll know of any other stored codes as well.
Whereabouts are you Raff?
Does seem a bit odd to map and then fit mods.
As above, see what else is stored too, hopefully none!
