Car was driving fine yesterday, however I did drive 20+ miles with the fuel light on yesterday evening, coming home from Sharon's parents. I had every intention of filling up first thing this morning as the petrol station is only a couple of miles away.
Went to start the car and it really stuggled before cutting out. Tried again and it started up ok but the EML light is now on.
The car spent last night on a very slight incline, so my thoughts are that there was hardly any fuel in the tank and the incline meant that it had pooled at the back of the tank. Therefore when I started it up this morning, there was little or no fuel at the drain hole meaning the fuel pump couldn't supply the engine, causing the stall.
I have since filled up the car and it's running fine, but the EML is still on. I'm guessing because the car had problems starting due to lack of fuel, this has triggered the light and it remains on until Honda switch it off. Is this the case as I've not encountered this before personally? If so, I really don't think I need to see Honda for them to switch the EML off if I can do it myself. Is it just a case of disconnecting the battery and leaving it for a bit?
Regards
Tony
Regards
Tony
