Hi again guys, Merry Christmas to you all!!! .
Thought I'd get that out the way first lol now to my issue.
The driver's side rear brake pads seem to wear loads more than the other rear and fronts. I changed discs and pads, then I had an issue with the caliper sticking back last year but I replaced the caliper with a new one so I've ruled that out, however, it continues to wear a lot.
I've changed the rear pads more than the fronts which can't be right. The drivers side rear pads need changing again, the other side and the front's are fine.
In the New Year I'm going to changed discs and pads all round again but wanted to check with you guys so I could check if there is a wear problem so I could deal with that too.
Any reason why it would wear so quick???
Cheers guys.
Cheers guys.
