Got some more done this weekend.
Got the rack raiser fitted with oem washers and o rings
New o rings
Fitted with new lock washer
Arms fitted with new crush washers and hammerited.
Fitted into the car
Looks abit cleaner now
Also done a few brackets to clean it up slightly.
Been meaning to do it for ages but only just got round to it and that's removed as much sound deadening as i can without removing dash.
Drivers footwell
Passenger footwell
What came out
Didn't weigh it as I couldn't be asked.
Managed to remove all the bushes now ready for super pro caster kit and shot blast my arms thanks to a really good friend. Will get them painted during the week, don't know if i should do arms black or blue!
Also got the drop links out ready for buddyclub ones to go in
Next task was painting a few more bits.
Fitted the JDM rear anti roll bar with superpro bushes,
Painted the rear strut
Fuel filter cover painted
Side brackets painted
Also my Oil Temp gauge arrived so fitted that so dash is no complete i think unless i find a double din i like. Cut a small hole in the dash to feed wire through and placed the controllers for the gauges in front so there easy to use with gloves on. Also painted the pods blue
As i finished
D1 Spec
From outside
In the day
Repainted my rocker cover gloss black and fitted flush cover. Got a finger print in it so will need re painting! (Dont ask)
Only problems i've come across is i think i replaced the battery while the rack was removed to lock the car as i have EPS light on and no power steering. I Used a friends OBD reader but didn't show any faults as it only ready engine management. I do have a WIFI OBD reader i use with Dash command but cant find it to see if i can reset it with that and hopefully that solves the problem. Unless anybody is close with a tech 2
Thanks for looking and hopefully should be finished in a couple of months.
