So next updated is an expensive one.
Fitted a new battery, actually the correct one for the car this time.
Full service and valve timing. Re sealed rocker cover gasket aswell to stop a small leak
To stop the problems with the IACV i orderd a rotation plate. No more strain on the wireing loom.
Steering has always felt sloppy so finally got round to fitting the Solid rack slider.
Went off to Romain for mapping. Surprisingly very quick! Car made power and lost torque. Drives so much stronger. 240bhp and 164lb/ft
So while having a play with a kit car i lost 3rd and 5th. Off to Birmingham i went to get a EP3 gearbox on 62k with a Quaife LSD fitted.
When removing the box the new seal i replaced was the cause of my oil leak! Not impressed.
Cleaned up and new seal in
M Factory lightweight flywheel went in first
New OEM clutch kit fitted and box on and went for a drive................... why havent i put a LSD in sooner. The car has changed dramitcaly so really need to find the limits again and re learn the car. Car now feels as it should, another geo and maybe add some camber as everything has been off and will be ready to get back on track.
Little test drive
After a Drive my oil cap decided it wanted to remove itself from the engine. Not once.... but twice.... so wasnt me being a **** its was obviously faulty. Little trip to honda and you cant go wrong with OEM.
Next will be new tyres, Braided clutch line, Clutch master cylinder and hopefully a track session!
