I had some horrible Falken FK452s on the front of FN2 before the Ring and Spa last year, RE050As on the back (FN2 OEM tyre).
I went to TDi for fitting of the Clockwise baffled sump and a other few bits before the trip and got the wheels rotated while they were off just to see what the difference was. Potenzas were much better when on the front, felt very grippy, turn in was much better and the back would pretty much slide out on command with the Falkens on the rear.
Potenzas are a good tyre is the point to that ramble.
Anyhow fast forward a few days and I get the rears replaced with some F1 Asymmetric 2s. Now I had to try very hard indeed to get the back end out. The back end seemed a lot more solid, but that was maybe due to the load index of the F1s being 92 as opposed to the 88 of the Falkens.
Payday comes, a couple of days or so before the Ring and I get the fronts changed from Potenzas to the same spec F1s I already had on the rears. The difference with the F1s was comparable to how it had felt moving the Potenzas to the front. Again stiffer sidewalls may have contributed to the turn in feel, but the difference in grip was unreal, particularly in the wet (it always seems to be raining the day I get tyres fitted. :roll: )
The Falkens had 6mm tread on them and I sold them on. Met the guy on the way down to the hotel in Fleet in fact. Changed them because the lacked grip, seriously lacked grip and that's why I changed them first, leaving the Bridgestones on.
The Bridgestones had 3 and bit mm on them, 4mm being the legal limit in Germany and so the main reason for changing them in the first place. I liked them but fancied a change. I didn't bank on there being such a big difference but I was swayed by reviews and group tests. I won't ever go back to RE050As now I've seen the difference.
TL;DR went from Pots to F1s, difference was massive.
Don't worry Dan, you've made the right choice.
