Guys in need of some help please.
My EP3 dosent get ran much during the winter so it struggles to start when I start it up the odd time - I usually use a booster pack to do this.
Been doing some work to the rear suspension the last week or so and this had been the first time it was started in a while prior to doing the work - I had to use the booster to start the car and reverse it out the garage and bring it back in so it was straight.
After the work was finished I went to start the car 2 days ago and it would not start no power to the car at all - I then tried boosting it without the key in the ignition if I remember correctly I cant actually be 100% sure and it would not start either - I thought the battery was just flat.
Charged the battery back up to full capacity and fitted tonight - As soon as I connected the negative terminal the alarm was going off so I locked the car with the fob then unlocked it - Alarm issue cured.
Went to start it and it will not start - It turns over fine everything has power but it will just not start - The green key in the dashboard is flashing and not going out and continue to stay on when trying to start.
I tried the spare key and it is not working either.
I have re-programed the fobs and checked all fuses.
Does this mean a call to Honda due to the green flashing key? I would have thought at least the spare key would still work?
