Hi all,
This is my 06 premier ep3.
Purchased a few weeks ago, had a bit of work done (drop links, cv boot, gear box oil change) couple of weekends ago at TI motorsport. When they changed th cv boot (front left) they couldn't knock out the ball joint, despite a lot of bashing..it's now got a bit of play in it and not sure if need a new hub or just a new ball joint.
Anyhow, since then a few noises have appeared.
First: only heard this when car is cold, turning left a real loud grinding noise is coming from the front left wheel, goes away after the car is fully warmed up. Tried to capture it on video here. Was no noise prior to getting the work done. I've inspected the car on a ramp and nothing I rubbing on the wheel, not the lining or anything obvious. Doesn't sound like a typical 'metal on metal' sound, can't really explain.
https://vimeo.com/212453226?ref=tw-share
Second: this also more apparent all the time. On the down rev and about 2000rpm or 20mph there is a definite grinding of 'metal on metal' combined with a metal rattle. My friend who is a mechanic says the clutch feels like it hasn't got much life left in it, next month or so might be on the way out. Have a listen here.
https://vimeo.com/212453269?ref=tw-share
Any help here much appreciated. Since buying the car, I've got 3 months warranty so would rather fix any big issues early on. I rang the company yesterday and they cover clutch, engine, braking system, steering rack.. all the major bits.
Regards
Steve
Regards
Steve
