How often do you use the A/C system in the winter i use mine more i think will it hurt anything using it in the cold???
craigiusmaximus said:How often do you use the A/C system in the winter i use mine more i think will it hurt anything using it in the cold???
Neily03 said:craigiusmaximus said:How often do you use the A/C system in the winter i use mine more i think will it hurt anything using it in the cold???
IT should be fine using it in the cold, unless it says otherwise in the manual?? :wink:
You should use it atleast once a week or the seals will perish and it will leak. :wink:
craigiusmaximus said:Neily03 said:craigiusmaximus said:How often do you use the A/C system in the winter i use mine more i think will it hurt anything using it in the cold???
yeah i looked in the book and it says it should be used below a a set temp cant remember what it is..... :?
Adambsmith said:IIRC it doesn't function below a set temp anyway.
Catz said:Use a fair bit for demisting just now however I must check out what temp not to think about using it ... don't want to break it!
Scousefella said:I used it today for "Frozen Assistance". :shock:
Sat in the CTR @ 0600 listening to 5 live whilst the heat done the job. :lol:
milano_chris said:Catz said:Use a fair bit for demisting just now however I must check out what temp not to think about using it ... don't want to break it!
It won't break - it simply won't turn on :wink:
donald said:Using a/c will only reduce your performance, so dont use it!! Unless of course you are one of these closet accord drivers in a EP3 shell..... :wink:
Mad Max said:donald said:Using a/c will only reduce your performance, so dont use it!! Unless of course you are one of these closet accord drivers in a EP3 shell..... :wink:
But I thought you had to use it regularly even through out the winter otherwise the refrigerant may lose its pressure and then you had to get the whole thing recharged? :?
