Honda Civic Type R, APRacing front brake kits Part numbers: -
CP5200-1057 : - 4-pot(BLACK) calipers, Ø330x28mm disc List £1358.23 + vat.
CP5200-1057R2: - 4-pot(RED) calipers, Ø330x28mm disc, drilled brake faces.
List £1377.00 + vat.
This kit requires a 17" aftermarket wheel due to OE 17" wheel spokes fouling
the APR caliper front face.
CP5570-1012 : - 6-pot(BLACK) calipers, Ø330x28mm disc, drilled brake faces.
List £1637.55 + vat.
CP5570-1012R2: - 6-pot(RED) calipers, Ø330x28mm disc drilled brake faces.
List £1657.00 + vat.
The 6 piston kits use the same size disc as the 4-pot kits hence they fit
inside the same wheels as the 4-pots. They do not require 18" rims!
Advantage on the 6-pot being, greater pad area than the 4-pot, ideal for a
car doing a lot of track day events. Down side, the pads are twice as
expensive as 4-pot types.
Brake profile / template drawings are available off the web. The drawing can
be printed off, cut to shape and used to check wheels for potential
clearance problems.
http://www.apracing.com/roadcar/brakekit/index.htm Top left picture shows 4
& 6 pot in also black & red versions.
http://www.apracing.com/roadcar/brakekit/data.asp Click the word HERE in
the text for profile and kit contents sheet drawings.
http://www.apracing.com/roadcar/brakekit/caliper.htm CP5200 / CP5570 gives
caliper type and pad details.
http://www.apracing.com/info/stockists.asp World Wide agents list.
