Gruppe M Scoop Question
Just aquired a Gruppe M well chuffed many thanks to rossy t. Having fitted it today I have found that I need to remove the scoop every time I would wish to open the bonnet. Is it possible to shave the scoop down to make the bonnet open? Also how would I go about re-laquering the scoop after I have shaved the scoop down or is it sealed by some form of clear resin???
Just remove the camlock screws each time :)
Are you using the scuttle panel provided with the kit or is it a DIY one?
After getting annoyed with having to remove the scoop everytime i opened the bonnet, i ended up taking the scoop of and sanding it down on the belt sander at work, i had to take at at guess about 3mm of it and that has done the trick as it no longer catches when opening the bonnet,
as for re-laquering i didn't bother to do it, as once i sanded it down it wasn't rough on the edges and it's not as if carbon will rust without it, oh and i'm a perfectionist so it's not as if i did a rough job as you cant tell it's been done, :twisted:
You only need to take off a few mills, wont make ANY difference if you take too much off.
