On Saturday my CTR for the first time started hunting. I pulled fuse 6 under the bonnet and reset the ECU by taking the car for a drive and letting it sit until the fans came on. It has been fine since but i was led to believe if the CTR is hunting then the main culprit is the ICV so this week i will be pulling the throttle body and giving the ICV a clean. will WD40 do instead of Carb Cleaner?
While i have the throttle body off i was thinking of fitting a Hondata Intake Gasket that i bought years ago. I have read that sandwiching it between two OEM Intake Gaskets is a better way to fit it. I have also heard it is a nightmare to get the Intake off but as i am just fitting the gasket can i not just take the bolts off from the Intake to the engine and pull the Intake back a bit to place the gaskets in position?
