After seeing these fitted to an EP3 Civic Type R i just had to have them, they suited the pre-facelift interior perfectly and i didnt want to pay £800 for a premier interior.
http://smg.photobucket.com/albums/v484/cavysri16v/?action=view¤t=IMG_0393.jpg
Although there was no guide on how to install them i thought i'd set one up for other people to look at.
To begin with the parts you will need to fit these to your EP3 are as follows-
Honda Accord Type R Recaro's
Honda Integra DC5 Seat Rails
8x original seat rail bolts
4x nuts to fit above bolts
2x M10 50mm bolts
35x M10 Washers to bridge gap between vehicle floor and seat rail on one hole.
First of all you need to remove the sub frame from the seat, This is bolted by 4 bolts in each corner, (keep these bolts as they are usefull to bolt the seat rails to the seats)
Then you need to match up the rear hole on the DC5 seat rail to the rear hole that you just removed the frame bolt from.
I then measured the distance between the rear hole on the DC5 seat rail and the hole which is furthest foward on the rail and then drilled a hole in the bottom of the seat to match, Do this on both sides and use 2x bolts for the rear of the seat rail, and 2x bolts and 2x nuts to attach the front of the seat rail to the seat.
As easy as that.
To fit the seat rails to an EP3 Type R you need to elongate 2 holes, The first one is nearest the door and you need to file this one downwards towards the floor 3-4mm
and the hole next to the centre console needs to be filed backwards about 5-6mm,
both of these holes are at the rear of the seat rails. Then you need to bridge the gap between the floor and the last hole you filed with as many washers as it takes (you can use other things but this is what i have used). * Please also see this guide http://www.type-r-owners.co.uk/forums/showthread.php?t=63464 as it is more in-depth.
You can then put them all together and bolt the seat into your car and check that everything works, and then do the same for the other seat.
2x M10 50mm bolts
As easy as that.
