reliability counts
Approved Trader
Hi all we have had many inquiries about horse power increase.
so id like to explain.
The stock k20a uk spec on a correct and caliburated dyno
Standard power unit mapped up does at the best 203hp@flywheel up around 9000rpm with 160ft/torque
Standard power unit with roller throttle bodies with different variant exhaust lengths diametre all tried etc, mapped up does 241hp @flywheel and 172ft/torque, 247max and you lose some mid range torque.
We then tried various head masking, valves, and cam variants available and even had our own cams made by a non uk specialised cam company with our profiles, that made between 8 to 14hp.
We found the only way to make above 260hp and onto 300hp is bigger cc with gains also from using a dry sump set up.
This experience has come from extremely long dyno work and its hopefully some genuine honest ( non bulls**t information and expectation for members of the forum to look at when they are contemplating building an engine
Budget for an engine that will produce well over 270hp like this is around £8k plus ( gives you something to save up for):lol:
NOTE, Just to add most engine rebuilds where you can have a good spec of forged rods a range of forged pistons and a complete freshen up would be around £2800 to 3k
many thanks Mike
many thanks Mike
