Harvey said:....loaded the standard tuned CTR map in and lowered my vtec point and put in a higher rpm limit...
So are you saying you lowered the vtec point and raised the rev limit or just stating the tuned map did this for you? I'm hoping it's the latter!
i am going in for my kpro soon using a 2nd ECU as backup....can anyone confirm if the keys are coded for the 2nd ecu...will they work for both ecu's then or one at a time??
Al you're right.
When the dealer recodes the key to your car after an ECU swap, his computer sets something to the ECU and the CAR.
Or at least he does it in a way that makes that ECU work only with that car. And the codes he inputs is only valid on that day, and is based on the VIN of the CTR and the code of the immobilizer that he gets from the ODB2 port.
Anyway that's what I've seen in my experience with KPro.
Al you're right.
Also, if anyone could tell me in laymans terms how to upload the new map to the ECU, I'd really appreciate it as I'm completely new to this.
If you are running an induction / exhaust, you could run the cold air rsx map
