The last couple of days I have had a very nasty clonk going over bumps and when turning.
So i had the car up in the air and began checking ball joints for play. No problems there. I then went round and check all sub frame and antil-roll bar bolts, all tight :?
I remember reading about worn top mounts a while ago on the forum, so though i would check these. I managed to tighten the nearside mount almost a whole turn :shock:
So might be an idea for everyone to go check their top mounts:
You will need a 6mm allen key(preferable as a socket bit on ratchet) and 17mm ring spanner. Place the ring spanner on the top mount nut, then allen key in the centre of the std. Be careful to hold the allen key still and square, you don’t want to munch it. Now simply turn the spanner clockwise to tighten.
